Help with setup | SatelliteGuys.US
Help with setup
loiviet
can someone show me how set up 30in dish.I mean my 30 in up to roof all i got strenght at 67 but no quality so maybe lnb problem ,i turn my dish everywhere but still no luck ,i need someone help i have the right lnb but how do figure out its working or not
More often than not, the problem is not with the lnbf. You probably either have something wrong in the Menu set-up, or it's the LOS (line of site), meaning you don't have it pointed correctly. You could have the wrong type of lnbf? What satellite are you trying to get? Where are you located (latitude & longitude)? What receiver are you using? What lnbf do you have on your dish?
Al
Muzak no longer FTA?
auto or blind scan
