Help with upgrade | SatelliteGuys.US
Help with upgrade
jcoppola
233
38
Charleston, SC
This is my first post but I have been hiding out in the background for quite awhile. I need help with a possible upgrade. I installed my own system in 2000 and was up on everything then but have since have not fully kept up. I have 4 rooms set up with:
6000 for my HD
501
(2) 301s
I have a 2 dish set up picking up 110 and 119 plus 61.5 all fed through an SW64 switch. I would like to retire a 301 and the 6000, and have the following:
622
625
501
301
Understanding that the 625 and the 622 have dual tuners what would I need to do to install this. I assume the SW64 will have to go.
Also is there much more that I will get with the 622 (or the 211) that I don't get with the 6000. I have the 180 pak with locals, voom channels plus Show and HBO now.
Off topic but does anyone know if Dish will ever carry regional sports nets in HD. For me that would be NESN.
Thanks everyone.
John
Your lnb's would have to be changed to Dish Pro Plus along with a DPP44 swich. It has four lines out of the switch with one line running to each receiver. The 622 and 625 would use a seperator (which comes with the receiver) to feed both tuners.
As far as rsn's in HD, word is 10 would be added. Nothing stated as to which 10 or when they would be added.
Need HD receiver advice
921 and Platinum HD
