The L-band frequencies of the behemoth dish cover from just above VHF channel 13 through most of the UHF band. The diplexer is blocking D10 from the cable.Could the fact that I am using a Terk OTA Antenna with a diplexer be the cause of me receiving the searching for satellite on the HD test channels?
This is one of the reasons that DIRECTV wants professional installers doing the setup. They have been instructed to tell customers not to use diplexers.
Funny, because I had a professional install my HD equipment and they are the ones that installed the diplexer to my system so that I could make use of my OTA and dish. This was an install I had requested in May as a result of the upcoming HD channels. At the time of the install they put in the Slimline dish, H20, HR20 and the BBC converters, along with the diplexer for my OTA.
I tried taking the diplexer out of the equation and I do get something different than the "Searching" screen but not a decent picture, mostly pixelations.
I feel like it is time to call DirecTV in to come take a look but I am a little aprehensive now that they are the ones that put in equipment that effects my ability to receive these new channels.
I have a feeling that there will be a lot of customers that use an OTA in the same position that I am in.
By the way, I am a newbie to this technical stuff so bear with me.
There are a lot of installers out there that haven't learned about diplexing and B=Band converters. And there are still more that don't understand the 5 LNB dish and HD. Some can barely install a SD System. This is new stuff and If I was not following these boards I would probably have not know that diplexers are a problem with the converters either.. D* itself hasn't really been very good at making any of this clear.. It pays to really stay current on all this and you have to really work at it in the fluid enviroment that is HD these days.
Limited time offer
