Help | SatelliteGuys.US
Help
knightwolf61
31
Houston, Texas
Howdy.....Does anyone know if adding a dp34 switch to a dishpro quad lnb will in effect give me 6 outputs?...Does each of the 4 leads coming out of the quad lnb carry the 110 and 119 signal?
Ok....The 4 leads out of the dp4 switch all carry both 110 and 119...But now for some reason the remaining 2 leads coming from the Quad Lnb somehow separated and one has onle 110 and the other only 119.....Do i need another dp34 switch for these 2 leads which would give me 8 outputs total or am i doing something wrong?
When hooking a DP34 switch to a quad you need to connect either ports 1 & 2 or ports 3 & 4 of the quad to the DP34. So you might want to check to make sure you are using the correct connections.
Azimuth and point angle for 129 using DISH 500 second dish
installing different receivers
