I hesitate to open another question on the Openbox S9 receiver since there have been so many written already, and I have read through most of them, but still have not found a definitive answer.
On some S2 transponders, Montana PBS on the Ku side, and even occasionally on the RTV S2 transponders on 87W C-Band, the picture and audio will display just fine for several seconds, maybe 15 - 20, then for no reason, hesitate, then resume playing for another interval.
I have even had Montana PBS drop clear out, and need to change the channel and come back to get it to start up again.
I don't think it is a problem with signal quality. On 125W, I have a dedicated Primestar 84e pointed there while it waits to be sold with an OEM LNBF on it. I had the same issues using the SL2 on my 6' Prodelin dish. I have 55-65 SQ most of the time, and LPBHD plays fine with never a problem. I have tried deleting the channels and transponders and letting it blind scan them all in new, but that didn't seem to help the situation.
This problem only occurs occasionally on 87W C-Band, but the same is true there. I have plenty of SQ, and should not be seeing any problems. That dish is a 10' perforated Unimesh dish with an orthomode feed on it.
I am using the FW that came with it, and have not upgraded to the latest because I have not seen enough significant improvement over the old FW along with slower blind scanning.
Have any of you tried the latest FW?
Have you noticed any significant improvement in any area?
Have any of you noticed a similar problem using the Openbox S9?
Let me know your thoughts.
