HIC question | SatelliteGuys.US
HIC question
gregleg
SatelliteGuys Guru
138
18
Pittsburgh, PA
For my 2 Hopper/2 Joey setup, one Hopper has a direct ethernet available, but the other does not. I tried using an old powerline adapter with the other Hopper (which works fine with our Roku), but that Hopper doesn't seem to keep a steady connection, so I decided to go ahead and order a HIC.
It's here (no idea if it works since I'm still at work, though :) ), but I see on the back that there's a "Mode" switch which isn't mentioned in the sparse documentation. A quick Google search doesn't turn up anything either, so I figured I'd ask -- does anyone know what this switch does? I don't plan on flipping it from the (presumably) factory setting, but I'm curious.
I'm not sure what the switch does. I just hooked mine up straight out of the box and never had to set up anything. The HIC worked right away and works well.
New to Dish, Set up Question
crackling & poping in sound
