This has been discused before. But, in case some missed it enjoy.
High-Def FAQ: Uncompressed vs. Lossless Audio | High-Def Digest
How about this:Why didn't someone make him say how good DD+ is!!lol
Please note, this is said by the person that mixed the soundtrack "We Were Soldiers". Is this good enough for you?I have done level matched side by side's with DD+ 1.5 decodes of "Serenity" and "We Were Soldiers" against the PCM masters...
I couldn't tell the difference, and I mixed "We Were Soldiers."
I mix films for theatrical distribution.... they do indeed have certain unique elements of craftsmanship and technical specifications.
And I don't disagree that most engineers that you speak with agreed with your assessment.
I did too, until I heard DD+ at 1.5.
The end result is the same whether the disc you buy has an uncompressed soundtrack or a lossless one
Oh, I have an open mind. Believe me. I consider myself a crazy audiophile and have a ton of friends who are the same. I believe in all kinds of esoteric concepts. I can hear fidelity improvements in power cables and interconnects. I can hear the difference between different S/PDIF cables. I can believe how someone thinks their music player system sound worse if a washing machine is running in another room. I can believe how someone thinks that an amp needs to break in for a few hours to sound good. Or how a $20,000 mono amplifier may sound better than a $1,000 one.
Indeed, there are few esoteric theories put out there by audiophiles which both the engineer and audiophile in me doesn't think there may be a shred of truth about it. This didn't come without having an open mind as you wonder. So none of this is at issue here.
What is at issue is that Rich is making claims I have not heard of anywhere after 30+ years in this business. I have read Perfect Sound for better part of a decade, and even that bible of audiophile music hasn't claimed that MLP codec (i.e. TrueHD) is not really lossless. Or that the same bitstream, coming from first layer of a DVD audio disc sounds different than the second layer. Or that if said stream is being transmitted to an AVR over a link, it can be subject to jitter. The equipment reviews in Absolute Sound read like wine reviews, but even they avoid going where folks seem to have gone here.
Because the space/bandwidth is available...so uncompressed audio isnt needed...why do they use it and waste all that space with it?
How about this:
AVS Forum - View Single Post - R&B Films - DRS Mastering for Superior PQ / AQ
Or would you like now somebody say PCM is not better than MP3...?
Diogen.
I don't care if HD-DVD doesn't have the ablility to support a lossless audio track (for whatever reason)-- I support the format that is capable and does support multiple lossless audio tracks on one disc -- BluRay.
I think he's talking about digital audio only.I thought the article was very good but only if you are considering sound in the case of these digital systems.
Correct. Only within those constraints you can actually talk about "lossless", i.e. it can be proven the compressed track is identical to the uncompressed.It can only be said to be lossless inside the digital box.
There are people that would not agree with you:The losses occur during the conversion from sound we hear to a file in digital and again from that file to a sound we hear.
Talking about the math, I still remember the day my professor showed the math on the whiteboard. Even after seeing it in black and white, I still couldnt' believe those "stair-step" pulses could be shown to be the same as the analog waveform. But there it was. It is one of those most non-intuitive things in A/V world. Even codec algorithms are much simpler to explain than this one.
Limited time offer
