Hispasat or Pas9 and Cubavision | SatelliteGuys.US
kelleyga
320
I have a 33" round FTA dish, a CaptiveWorks Dual Ku-Band Universal Linear Standard LNBF, and a Viewsat Platinum.
I am trying to see either Pas9 or Hispasat to pick up Cubavision for my father-in-law in Central Florida. With a satellite finder I am picking up signal in the approximate location of where I think both birds should be, but the Viewsat doesn't show anything.
Should I be able to pickup one or both satellites with the equipment that I have? I know that I should get signal from the area, because friends of my father-in-law are getting it with other equipment.
Any suggestions?
well what u can do is set up the box for a universal lnb at 9750 and inter the right transponders I got that b4
good luck
Any suggestions?
Are you sure the LNB is universal? If so, make sure the LNB setting is for UNiversal (9750/10600)
Rumour is PAS9 doesnt have Cubavision anymore so you will probably have to shoot for 30W. Florida has a good shot of it (heck I can get it in Minnesota with a 9 elevation) ;)
Check thelist at the top of the page for transponder info and also aiming calculations
As far as I know it is universal, at least that is what it says on the box. Is there another way to tell?
I had the Viewsat set to Universal LNB and the Hi/Lo to (9750/10600). I remember trying TP 11884 as well. I used the SR-FEC
SID-VPID info from Lyngsat. Not sure what else it could be.
To be honest, I was trying harder to get Intelesat 9, since Hispasat is really low on the horizon, and there were some trees that could have been affecting the signal a little.
As I mentioned, I was picking up faint signals from both, but neither were strong enough to register on the Viewsat.
Could it be the LNB? Here is what I have Universal Dual Ku-Band LNB LNBF Linear FTA Satellite - eBay (item 320341802068 end time Mar-17-09 23:39:23 PDT)
I live in Melbourne Florida I have a motorize system I have also installed a fixed system for my mom in Tampa. Make sure you have the skew on the lnbf correct.
Let me know if I can help you I will do what I can. Be back on here later. Hispat is the one you want he will get many more stations from Cuba, Spain, Argentina and more
Any suggestions?
Shoot for Hispasat;)
The specs in the ebay ad state it is a standard lnbf, its written on the box in the picture also.
LO freq 10750.
WOW! Not sure how I missed that! I guess I had a blonde moment.
Probably because the title says "Universal" Dual Ku-Band LNB LNBF Linear FTA Satellite.
So should I buy a Universal LNB instead? It sounds like you guys are saying that if I set the Viewsat to Standard, and set the LO to 10750 that it should work, but I am just wondering if a Universal LNB would pickup the signal easier.
Sorry if these are dumb questions.
a standard will be fine for 30W. I've used standards with no issues
UNiversals just get the lower frequencies (10.7-11.7GHz) that some atlantic and most european sats use
KUIL?
Coolsat 8100 Audio Problems with NBC HD
