Hispasat with 4 receivers on one universal dual LNB | SatelliteGuys.US
johnny33156
44
2
I tried connecting the 4 receivers to 3X4 multi switch but after
I connected the 3dr receiver up to the switch the picture started to
break up on the other two receivers.
Does anyone have any experience with this?
Thanks for any help.
since you are using a Universal in each of the receivers try this
change the LNB Frequency (LNB LO) from Universal to
Single or Standard
LNB LO 10600
22k ON
or just switch to a standard LNB ;)
Thanks for the help.
It worked.
Still using universal LNB
I changed the LNB type to standard.
22K on.
sounds good
I think the issue was Universal there is a low band (10700-11700) and a high band (11700-12200) and the "default" it goes to is low band so the receivers were fighting each other to go to low or high band. With the changes you made the receiver defaults to "high" band
PowerVu receivers
True South vs True South *satellite*
