Hitachi w/ 811 remote ? | SatelliteGuys.US
Harry
305
Las Cruces, NM
I have a Hitachi 46F500 RPTV that I use with the 811. The 811 remote works with the TV except for the select button. I've tried every button on there but no luck. I can navigate around the TV menu but just can't select anything.
Anyone else have this setup? IF so, does yours work?
I had the same problem my Sammy 42"DLP. I select the TV button then hit the HD/SD button and it brings up my input menu. I can move around in there and when I select I have to press the Volume bar "up". (just kept hitting things until it selected).
Thanks, I'll try that.
Have you canceled your $9.99 HD Package?
Any Opinions on dealing with Dish Network Regarding 811 receivers?
