Home media mp4 fixed U307 | SatelliteGuys.US
Also noticed it no longer brings you to the introduction page, it now goes straight to the device list like it used to on the HWS...:cool:
Sent from my SM-G935T using Tapatalk 2
Mine still goes to the Introduction page first.
Also not all of my mp4 files play. Only about half of them. I haven't figured out yet what makes the difference.
There are too many variations of MP4 based on what codec what used to create it... I will not re-encode all of mine just to suit the Hopper's media player. Plex plays them all flawlessly. I ended up buying a Roku stick for our living room TV that we use instead of the Hopper.
I'm using the Windows 10 DLNA and I see a warning in the event log every time a file won't play.
But Hall is right. It's fine. Not gonna re-encode everything that doesn't play. I have better things to do. I just right click on the file and cast it to my Sammy TV.
I have m4v files with codec H.264 and am using Plex
I should clarify - I have a media server enabled on our Asus router as well as Plex server set up on a PC (both pointing to the same files). With the Hopper, playback of non-MKV files doesn't work from either server (MKV files do play though). I do have (2) Rokus - one box and one stick - and the Plex client installed on both. The client plays all of the MP4s, MKVs, etc.
I didn't have a chance to test with the U307 but got U308 today. I am able to play mp4's now. Was frustrated that I couldn't pause the playback when I accidently hit the back arrow next to the select button. It brought up a menu at the bottom of the screen with a pause symbol as one of the icons. I used the arrow keys to select pause and pressed select. The movie paused. Still can't fast forward or rewind but being able to pause is a huge thing. My dvds are ripped as MP4s and my Blu-Rays as M2TS. The Blu-Rays are ripped using DVDFab. The DVDs were ripped by some no longer available software from AIESeesoft.
I am using TVersity for the DLNA server. I tried a MKV passthrough but the movie stuttered a lot in playback. This is most likely due to my media server. It is getting really old. The CPU is an
AMD Athlon 64 X2 Dual 4600 2.4G. I only have 2 megs of ram. I know I need to update this server but real life expenses keep pushing it down the list.
I can now play almost all my media from my Mediabrowser server, DTS encoded files seem to have the audio cut out every now and then, but that might be a transcoding issue on the server side. I do have a problem where sometimes if I'm watching a video and stop it, it will freeze the picture and I have to reboot to get any control back.
Upgrading from hopper 1 to hopper 3 question
HDMI Cable Quality
