As you might have notice I when coming to SatelliteGuys now, you come directly to our Forums instead of our Normal Homepage.
It looks like the homepage is not compatible with the new version of PHP our server is running and is throwing off errors in the logs and also not formatting correctly on users screens.
I have taken the homepage offline as I continue to work on it and hopefully it can be returned. There is also other homepage portal software that works with this forum software. The portal software we are using now is old and has not been updated in quite a number of years.
I am still working on updating the links in the top bars to reflect this change.
Thanks for your patience!
