Homeplug question | SatelliteGuys.US
Homeplug question
HotLZ
25
I have two 722's that I want to get online so I can schedule events remotely when that becomes available. I'm going to use a homeplug to do it. My questions are:
- the 722's have it built it, so I only need the one end that goes from the outlet to my router, correct?
- how does the homeplug differentiate between the two recievers?
- Is there a particular version of homeplug that I should look for, and where's the best place to buy? Thx.
Thanks for the link, that was most helpful.
I do have one more question: in Dishcomm setup, my upstairs receiver was not showing the downstairs one, and vice versa as well. I manually added the downstairs receiver to the upstairs config, and all I get is offline for status. Then I went into the dishcomm setup on the downstairs receiver, and it now had the upstairs rec. added to it's config automatically, but the status was offline as well. They use homeplug for that communcation, correct? I'm not using any powerstrips, straight to the outlet.
Why the offline status and how do I fix it?
Dish Retailer Chargeback
Combining off air and satellite feeds
