Hook up multiple TV's with splitter | SatelliteGuys.US
SVTCobraLTD
10
PA
How can this be done? Is it done before or after the box? What is used to change the channels? I have 2 satellites on the roof, one HD and one SD. Right now, the HD one is hooked to a 422 box and there are two tv's running. I see the previous owners had many tv's hooked to these two.
Sorry it is ViP222k. Have 2 satelittes on roof. 1 at HD and 1 SD. Right now only HD is being used. Cable comes into basement and then goes to room where main box listed above is. Other room has attenna attached to cable line in.
you most likely have a diplexer in the basement
it looks like a splitter, but should be labeled differently
the uhf port on this is feeding the 2nd tv and can be run to a splitter
whatever tvs you add will need to be set to the same channel as tv2 is now, usually 60 or 73 and will view the same program at the same time and use the same remote
Question on External Hard Drives
So far....so goog
