Hook up problems | SatelliteGuys.US
Hook up problems
Bud Kerr
6
Durango, CO
I disconnected and took my Dish 625 receiver on a trip to Arizona last month. When I got home I reconnected it as it was before (I took pictures). Now I can't get any picture on TV2. I have gone thru the book concerning the right channel etc. Here is a drawing of the setup the Dish tech. did upon original install.
Do you see a problem?
Drawings
if diplexed make sure the uhf side is going to tv2 ijnput/output. if hardwired do same.check connectors make sure diode is flush,stinger not bent.check modulator setting. Auto program Tv 2 to get disired channel.Some tv loose there memory if you unplugg or throw the breaker, power outage etc.
Trouble with 119 signal
grainy picture on tv2
