dlh1435 said:Does anyone know if the xbox 360 dvr will work with dish?I like to use both the 360 and dish dvr.
\h3x said:What I think he's trying to say is.. Will Windows Media Center Edition 2005 (which is what the XBOX 360 uses to stream video) work with the Dish Network DVR Receiver..
In a nutshell, would he be able to hook up his computer to his Dish DVR and pull in channels off the receiver box.
tawhite said:And that will work with a dish box but will only be in SD as MCE currently only supports OTA HD.
I've been waiting on assembling an HTPC and purchasing an Xbox 360 until the release of Vista... I was hoping everything would be communicating effectively. Sounds like it may be awhile thoughroachxp said:I'm actually testing beta drivers for MS Vista Premium with a Comcast cablecard which slides into a pcmcia type pci-e slot card. Right now the DRM is a pain. Hopefully MS releases a 360 update for Vista once it's released so we can stream regular HD. The wired part is Vista can see all 3x360's on my network but the 360 don't see the pc.
Allin4greeN said:I've been waiting on assembling an HTPC and purchasing an Xbox 360 until the release of Vista... I was hoping everything would be communicating effectively. Sounds like it may be awhile though![]()
i've been trying to hook my xbox 360 up to my tv through my dish network receiver and i cant seem to get it to work and i was wondering if there is way to do that??I dont think he's askin that.. if he is... the answer is no..
MattG DISH Network receivers don't have any video inputs. So no said:actually i meant cable box and how can i hook it up
Limited time offer
