Hooking up 2 receivers | SatelliteGuys.US
schofield765
2
Can anyone give me info on how I can connect both my 5900 PVR and a 9241 HD PVR. Connection so far- 2 Dual LNB's each connected to SW21, 2 RG6 cables going into house and both plugged into 9241 HD PVR. Can I split off one of the RG6 ( with a switch ) and connect it to 5900 PVR? Any info would be great thank you.
You would need to replace your SW21 with a SW44 and run a new line from your 5900 PVR to the SW44. The lines cannot have splitters after the switches.
Ok i will look into that. Thank you very much
Yep, that is simplest way now to connect 2 receivers for sure.
Just replace BOTH LNBF's, remove the SW21, run 1 line to each Receiver, add the DPP Separator behind the 9241 and away you go. No Dish re-alignment as long as you don't move it when removing the old LNBF's.
