hooking up 722 to ethernet questions | SatelliteGuys.US
A_Pac
67
my 722 is really far from my router so a cable run is the last thing i want to do. i have two 802.11x routers that are wireless/wired. one i use for my computers and the other is inactive. is there some way i can use the 2nd spare router to broadcast or something to my other router to avoid the long cable run? thanks in advance
want to do this for phoneline/on demand
You could use the Ethernet over power devices available at rat shack. It uses your home power wires for Ethernet connection I think they are 10base t also. Or run a Cat5 and call it good I know you don't want to but thats the best way.
Just Invited to use trial software!!!
Sign Up NOW for remote programming!
