Hooking up two HD tv's?? | SatelliteGuys.US
taylor76
2
Please help me...im so frustrated!! Can someone please tell me what im doing wrong....I have to HD tv's that I want to be connected to my Cablevision box...I have them two feet apart and want them to both play the same stations. Ive got a picture on both tv's but one is fuzzy and B&W. Anyone hear of this before. Thanks.
component video cables..that should work right?
Although I just found another post that mentioned hdmi cable for one and video cables for the other...this way they both have sound...does that sound right?
Sounds like you may have a bad cable or a bad connection. Try disconnecting and connecting them again. Also try switching the connections: see if the problem will repeat on the other TV set.
If you have HDMI - that might be a better way to go.
How are you using one set of component outputs to feed two sets of component inputs? Are you using a distribution piece for it? Or do you have two outputs on the box?
Because I certainly hope you do not have three Y-adapters.
A/V Receiver upconverting SD SAT signal?
Cyberhome SonicVoom CH-SRD600R Consumer Headphones
