hoping for better picture | SatelliteGuys.US
randy
ive had my 811 for a few weeks now and i think my picture should be better than it is. im pretty sure the installer hooked everything up right. my tv is a sony 32'' hd trinitron. any help would be appreciated...
Randy,
You need to tell us more about your situation or you are going to just get posts stating 811 sucks!!! How is your Sony 32" connected to the 811? Is it through the componsite, svideo, Component or DVI? What source material are you viewing? HD? SD? OTA analog? What are you configuaration settings for the 811 in terms of video output. 480i, 1080i ror 720p.
To get the most out of your 811, go with component or DVI and 1080i.
Also check the software version (menu-6-1-2) to see if you are running the newest version (P266), if you do not have that, turn off the 811 for a while (if you leave the TV on you will see it do the update).
Mitsu TV only works on 480p
DishPro 500: Can't get a signal in Chicago
