I found that when your watching some shows it says press select to watch from beginning and you can now see the whole show information by pressing page down.
Amazing updates, it works when you press the play icon on the remote.The update for the Joey showed the release notes, lots of upgrades to the On Demand feature. There is a play icon in the guide listings for any show on Demand so if you come across a movie or program in the guide and you want to watch it from the beginning, you just select the play icon. Also if you are binge watching a TV show On Demand when you press stop you are given the opportunity to watch the next episode.
Edit: Apparently the play icon is just an icon, when you press OK on the program you are given the opportunity to record it, watch on demand, see program info. If it's already airing you have to press info on the remote to get the option to watch on demand.
It's the green button on mine.No release notes when unit was powered on and the only change I've found so far is you can turn on Closed Captioning without going into the settings by pressing the orange color button. There might be some new apps, not sure.
I also apparently got this update on the initial spooling. That's never happened before....
For some reason this feature doesn't work for me. It works for my son, but not for me. I think that my Hopper hates me...I like the new feature when pressing "stop" on a recorded show that it brings up additional episodes you've recorded. I tend the get behind on shows and catch up in one evening. This is very handy.
Does your Hopper have S512 or S446?For some reason this feature doesn't work for me. It works for my son, but not for me. I think that my Hopper hates me...
S446. But I think I figured it out. All of my show are on the remote Hopper in the bedroom, which hasn't been upgraded, while his are local to the living room Hopper. I don't know if it will work when the bedroom Hopper is upgraded or if it only works locally.Does your Hopper have S512 or S446?
Lol. Patience young grasshoppa
Limited time offer
