Hopper 3 issues | SatelliteGuys.US
Hopper 3 issues
It has happened to me three times this morning on my Hopper 3 while watching Netflix series. I am on U925. I have fired up my second H3 to see if it happens on it too.
Reactions: Howard Simmons
I have not had any problems with either of my Hopper3 receivers in Plain City Ohio this morning. In the past I have had a reboot occur during bad weather when I lost satellite signal. This even occurred when I had switched to an OTA channel. My software version is U925.
On the weather forecast I see that there is a strong line of storms across several Midwest states. I wonder if that could be causing your problems.
Reactions: charlesrshell
I've had the same problem. I had thought it was due to the fact that most of the local stations in Chicago had gone out of service due to massive flooding.
You can add me to the list with Hopper/Sling! It would reboot then come back on for 5-8 minutes and then go blank and reboot again.:mad: I just shut it down and wait till later this afternoon to check to see if it's still messed up. It's got to be in the Dish system.
Now that you mention it, I fell asleep last night with my Wally on. When I woke up after midnight, the TV had nothing but a black screen. I pressed the SAT button on the remote, and the Wally came back on right away without any problem. So, I did not think anything of it, and I went back to sleep. I have not turned on the Wally again today to check it. If it was the same issue that everyone is reporting here, though, then it must have started happening sometime around midnight.
Mark at DishDepot Retiring
self install
