Hopper 3 moca network question | SatelliteGuys.US
xan326
USA
Before I get into it, I'm new to moca networking, so I don't know the limitations of it.
My family has been looking to upgrade to Hopper 3 with a couple of 4k Joeys, so I've done some looking around and saw that they're using moca networking between the Hopper and Joeys. We have cable internet from a local isp, and they're also offering moca for in-home networking, and we've been thinking about doing it to fix dead areas with our wifi network.
My question is, is there a way to somehow combine the two moca networks to reduce the amount of cabling and devices? I can't seem to find any information on this.
Basically, I have my modem/router where the Hopper is going to be, and I need a router where one of the two Joeys are going to be.
The moca the h3 uses communicates over the coax cable that the receiver/boxes connect to.
If you have problems with dead WiFi areas you might want to consider one of the new mesh router systems. I set up a google WiFi system in our Church and it works really well with no additional wiring.
DishAnywhere.com doesn't show Video On Demand movies on PC
Hooper HD failure time to go to Hopper 3
