Hopper 3 replacement | SatelliteGuys.US
Technically it will work with the hub but what may cause issues is the dish hyprid lnb as a 211 uses dish pro plus lnbs. I've been to service calls were they had one on a hybrid with no issues though but also to another that was having issues. But most likely you can just pop in the 211
HBO Max not working on Hopper Plus
Dish Identity Force does not work
