Hopper 3 youtube app problem. | SatelliteGuys.US
Rixos
224
71
Sacramento
Anyone else having problem with the new youtube app? It worked for a day or two than stopped working. When you click on the app or tune to channel 371, it shows youtube starting or loading screen for couple seconds then it switches back to a regular tv channel. I tried to restart the receiver couple times but so far no go. Any ideas?
mine was doing that last night before i went to bed also too also the sounds horrible when you try to bluetooth the sound on a 5.1 sound system could dirt please check into this also too.
Reactions: Rixos
Our Engineering team is currently investigating the issue. Please let us if the following resolves the issue. Click Menu > Settings > Diagnostics > Tools > Reset to Factory Defaults > Reset YouTube to Defaults.
HI Lalia also have the engineeing department also check into improving the sound when you try to stream a video it sounds horrible right now when you try to stream a video on youtube sometimes it sounds like chipmunks on my videos i know my videos do not sound like also when you try to stream a video the sound of the video wants to cut in and out thanks allen
I do not even have the app. Is resetting the Hopper, ok if you do not have the App
I just posted about this. I didn't see this thread at first. But yeah, same with me. Just as I was getting spoiled not having to go through Apple TV or the PS4.
I have to do this almost daily and have Dish install a new hopper, I can bypass the hopper and connect the tv directly and it works fine. By the way I have Att internet
On my Hopper 3, I have an issue almost daily with the YouTube app where it will randomly speed up and skip ahead several seconds at a time while watching a video. Rarely, rewinding the video will fix it. Usually, the issue will repeat again after rewinding it, although the skip does not necessarily happen at the same place again. This tends to happen near the beginning of the video, although I have seen it happen farther into some videos. Whenever this happens, I exit the YouTube app, go to Diagnostics > Tools, and then reset the Hopper. (Not a factory default reset, just the regular reset button in the upper left.) This fixes the issue for that day, until the next day that it decides to screw up. Often when I re-enter the YouTube app after the reset, the video I had been trying to watch will be the top recommendation, but other times I have to search to find it again.
  • Sad
Reactions: TheKrell
Wally not switching odd/even transponders
hopper 3 delayed viewing, turn on joey 3 removes buffer??
