Hopper 52.0 remote issue | SatelliteGuys.US
a2zvisa
63
4
Visalia, Ca
Hello, I have a Scepter U650CV-UMR tv. Although I can control the volume with the DISH remote 52.0, I cannot change the input or anything else for that matter. So to explain in detail, I press the TV button on the side of the 52.0 remote, the "Press SAT to Watch TV" warning immediately comes over the screen, I press the INPUT button on the side of the 52.0 remote, the "Source Select" of the Scepter TV comes on but I cannot move the selection using the directional keys of the 52.0 remote. I have tried all available codes by manually entering codes within the "Pair TV with Remote Control" screen in Settings. I have tried the "TEACH COMMANDS" as well. Nothing seems to work. The inconvenience with this happening is in order to watch the Apple TV, ROKU or Fire TV, I have to bring out the actual TV remote to change the input. Not life threatening but annoying none the less. If anyone has some additional suggestions, I would appreciate them! Thank you!
Try this. Press and release the TV button and then press the Input button multiple times to move the selection.
Same behavior. If I hold the TV button on the side of the 52.0 remote down, the Scepter tv will alternate between the Source Input Selection screen and the Input ID screen. Thank you. Appreciate the help!
Joey from eBay
Mystery Rebooting, Please Help
