Hopper Goes From Watching DVR to System Ingetrity Check 770 | SatelliteGuys.US
dangerousdave
51
6
We've had the Hopper for about 10 days.
I was watching a DVR show from last night and my Hopper suddenly goes to the floating turned off screen. After getting a little upset I pressed select and a minute later the Running System Check display comes on the screen.
A few days ago, I was FWD a DVR recording at 60x and was unable to stop it, including trying to turn the Hopper off via the remote. The only way I could stop it was pressing the reset button on the front of the box.
How common is this problem and is it being addressed by firmware updates or what?
I'm not sure about not being able to stop the fast forwarding as I haven't experienced that problem, but you can increase the time it will "go to sleep" by going to: "settings" "diagnostics" and "updates." The default is two hours. I changed mine to four.
Reminder: HBO Free Preview on NOW (May 14th) thru Wednesday
VIP receiver on a Joey/Hopper setup using separate account
