Hopper icons missing | SatelliteGuys.US
satjay
12,720
898
Michigan
Hey guys love the Hopper system, but since the new software has come while I like that we can now pick which hopper recordings we want to watch I notice I have to reset the hoppers as the icon goes missing on which hopper you want to watch recordings on. I was wondering if dish was aware of this issue and if others are having this problem
You have an icon to choose which Hoppers recordings to view?
All I have is a dropdown menu.
Sent from my DROIDX
It's for a sure a bit frustrating as after a couple hours of the tv off I lose the ability to choose which hopper I want to watch, maybe a future software upgrade will help. I also changed the inactivity setting to see of that will work, but did not
Yep same here playing recordings from the other Hoppers is pretty unreliable. Only way to fix is a soft reboot of one or all of the Hoppers.
Well at least I know it's not a isolated problem, hopefully future software updates will fix this
I have a major problem. I have 2 hoppers and 3 joeys. I recently found out that Dish added the feature where you can share DVR content between hoppers, but I no longer have the option to choose between them. I used to have that drop down box on my DVR menu, but it's gone! Can anyone help me or suggest how to get it back? Thanks.
EPG Remaps
warning : movers and service address bungle.. doh
