Hopper Install Issues! | SatelliteGuys.US
Poke
13,886
238
OK
Well going on 6hrs try 2 different Hoppers ran new cable tried 2 different Nodes try 2 different LBN's everytime the tech boots the Hopper up it goes to a Check Switch Screen 833 then got to 015 screen Satellite X.. Called Advance Support they said Go to Settings then hit Factory Default once the 833 Screen comes up and wait 15 minutes. We have power cycle the Hopper so forth Tech said it should go to a setup remote screen. He tested all 3 Sat's 119,110,129 at 100% at this point this has turned into a bad day... Dish Anyone have any ideas?????
If it shows an x in place of an actual orbital, then checkswitch failed cause hopper is not seeing dish. Do a manual checkswitch from in the menu, report back.
I've heard of node stickers being on backwards before. What color is the inside of the terminal for the host line?
I will have to check with the installer tomorrow he is gone for the night..
Easy Fix! Well we tried 2 different sets of LNB's,2 different Nodes,2 different Hoppers. Well Tech called today said he hooked one of those Nodes we have tried and it did the same thing to their Hopper at the office. Who would have thought that 2 Nodes would be bad so he brought the one from my friends office hooked it up and it worked like a charm took less than 10 minutes. So like they say 3rd time a charm.. :)
PTAT issues
Which do I need - 1 Hopper/3 Joeys or 2 Hopper/2 Joeys?
