Hopper ota and setting recordings | SatelliteGuys.US
joshwright76
US
Dish installed an ota adapter and antenna at my home and I get all my local channels.
But the guide only shows information for the current hour. How am I able to set recording timers on the OTA channels?
This is kind of primitive but I think it will work for now. Find a TV guide for your local channels. This is what I use. https://titantv.com. Find the show you want to record and then locate the channel and time slot in your Hopper guide and set the timer.
When was this installed? If it was today then you'll need a guide update. You can usually force a guide update by turning the Hopper and all connected Joeys off (standby). Also be sure there are no recordings scheduled for at least 30 minutes.
The first 2 or 3 days can be a bit odd. Even for reading EHDs.
If this was installed more than a few days ago, and the standby doesn't work, we have a problem.
Great customer service
Hopper 1 - Boot Recovery 981 message (12/11/18)
