Hopper OTA Module Recording Trouble | SatelliteGuys.US
Hunter Mackenzie
81
2
I just installed the OTA Module for the Hopper with Sling and for some reason a few of the OTA Subchannels will not record..For example Channel 4 has Cozi TV as its subchannel 4.2 I see the guide info but when I hit record it does nothing and scheduling an event does not work either but the subchannel on Ch2.2 works with the record feature any thoughts?
This is it. The thread was OTA Timers Not Working" and not far below this thread.
Do a search when posting about a problem
I've copied the info. I'm just reposting what someone else posted.
This is it
I've figured out what works for me. If I bring up the channel and program I want to record, I then press the record button three times. This brings up a screen giving a few options. Tab over and select 'manual timer' which then changes the screen again and hit create, after you have made any changes you want, like start/stop time.
If you don't tab over to the Manual Timer button at the bottom, this will not work.
Any other sequence will not work.
Whenever the next software release is. It would be nice to have atleast a guess as to when the next update should occur.
It's not worked since May software update and the last software update I got on my hopper was on June 26th. So I'm hoping that the two month wait for the next one will be the update that fixes the name based recording on the ota sub channels.
There won't be a fix till the next software update. When you start hearing about people getting new software, then ask them if it's been fixed. DIRT has no control over that.
Sure Dirt has no control, but being they are "tech support" they should be able to post a time/date.
Or are they here to just to look at our accounts and see/track what we are doing/saying?
MLB blackouts on ESPN
Prime Time Anytime
