I had two Hoppers installed last Thursday. Noticed recently that both are suffering infrequent intermittent picture freezes. I can channel up or down which corrects the problem until the next one.
Check the signal levels when the freeze occurs, sounds like the dish may not be pointed correctly.
Thanks MikeTransponder 19 or 21 on 72.7 and I'm not sure which one on 61.5. With the exception of your locals , there isn't much on 61.5 anymore in hd , mostly sd channels. If you are getting 60 to 70 on these two sats it isn't your sat dish aim and peak. Have you run a check switch run lately? ON hoppers they periodically need to have the check switch run again to clear out the bugs , so to speak. I had this happen when I added the super joey last month. Picture was freezing or jerking etc, and certain tuners were not working or saying they were downloading the guide. I ran another check switch and it cleared out the bugs .
Limited time offer
