Hopper timers | SatelliteGuys.US
Hopper timers
dishcomm
10,388
554
suburbia
I am trying to help out a friend on a timer/programming issue.
He has Hoppers. My friend told me Hoppers do not have the ability to 'manual time' programs.
Meaning, A) one cannot set start and end time manually..
B) cannot simply press "record" and then record a program or portion of a program.
Answer to A & B is "yes they can". Select the timer in the timer list and then select "edit timer" for "A".
Posted Via The SatelliteGuys Reader App!
Once a timer is set go to dvr, select timers from drop down. Select show & then edit. Lots of customization settings there.
The name of the recording will have channel number and name and recording time range.
The VIPs would let you edit the name (in initial Cap) but Hopper does not.
-Ken
Dish 211Z User Interface - Is it the same as the 211K
Anyone use the DS2PVR to copy from their Hopper
