Hopper with Sling has wireless? | SatelliteGuys.US
ChairBound
205
28
Spotsylvania, VA
In reading the posts about the newer Hopper with Sling here, I came across a post that talked about the unit having built in wireless. In skimming through the manual, I do not see this mentioned. Does anyone know if that feature does exist? Thanks in advance!
I switched to the built-in wireless on one Hopper with Sling. It enabled me to take my Hopper Internet Connector out of the architecture, since "bridging" also works well. As a result, the entire set up (1-Hopper With Sling, 1 Hopper, and 4 Joeys) is more stable. No more "looking for Hopper" every time my home wireless router reboots.
211K Buffer
Can you rename your HWS after initial setup?
