Hopper with Sling Software Upgraded to S523 | SatelliteGuys.US
When I turned on HWS this morning there was a pop up window that said Netflix is on channel 370. I checked the guide and channel 370 NETFLIX is there and also noticed BLOCKBUSTER@Home is on channel 375. In the Main Menu screen the Blockbuster icon is no longer there.
We have S520 and Netflix is on 370, has been since S520 came out (I think). Seems quicker to get to Netflix than blue button or menu.
Blockbuster @Home is on 375 with S520.
Well, the remote control delay/freeze issue is still not fixed. Worked good all morning till just now. Nothing brings the Hopper out of the freeze up except wait a few minutes till it catches up. It is wired how when the Hopper is in the delay/freeze up mode if you press the Main Menu button twice to see the System Info screen, it says no remotes connected to the Hopper. :(
o_O
so what is going on this new software releases ao_Ony new perks?
It's got a viewers choice option. The more you use certain apps, the more it removes apps that it thinks you don't use. That way it opens up more memory for storage for TV shows. o_O
Might come back to satellite
TVs with Dish Joeys go black and lose audio
