Hopper with Sling software version S328 is here. First thing I noticed when I saved a PTAT recording the little blue S does not show up in the icon. Will update the remote control color button list later today.
I just discovered a remote control issue. With TV and Hopper in the off mode and remote control in the satellite mode, when I press the top power button the TV and Hopper turn on. Prior version only the Hopper would turn on and then I would press the lower power button the TV would turn on. My Hopper is connected by HDMI direct to TV. I do not like this new change. Got to run some errands. Will check out all the remote color buttons when I get back.
Yup that's new. I kinda like it but they should give you the option to turn it off.
Posted Via The SatelliteGuys Reader App!
That is a new feature, HDMI-CEC not only will it turn your TV on, but it will change the input on your TV to the input your Hopper is on, in case your kids or someone else used your tv to do something like play XBOX and didn't turn the input back for you.
This feature can be turned off in the Hopper's settings if you don't want it to do that.
I noticed some small changes. The tiles in the DVR menu look a little different. Can't remember if they always had the number of episodes recorded showing in the corner of the tile but it looks different now. I also noticed that when watching a DVR recording when I am done watching the show it will bring me back to the tile I was on. I think in the past it just brought you to the top of the DVR menu. This is great for when you're watching the multiple episodes of the same show. Last night I was catching up on The Walking Dead when I noticed it, great upgrade.
If you are watching a series you can always create a playlist and setup autoplay so that you don't need to go back into the DVR menu each time.
Is this new? When skipping back or forward it shows a little icon in upper right side of screen with either 10 sec. back, or 30 sec. forward. I don't recall seeing it before new software.
Oh really? I know people had asked about doing this in the past. Is this new or have we been able to do it? That's perfect for watching a series or setting up shows for my son to watch.
Limited time offer
