Yes I agree. Do you have a solution to get them to be recognized? I just re-formated another xtra 2tb drive in Win 10 on the PC and the Hopper3 recognized it and is formatting it right now. But I dont want to do that to the 4 drives that are now unusable and loose all the years of recordings.Its not taking out the drives it's simply not recognizing them. My 500 GB drive still "works" but my other larger drive with 599 episodes of the Simpsons does not.
Not all drives/users are affected by this problem
I just want to be certain, is everybody not seeing their EHDs looking in the Sources folder, or is that folder missing...
My 4 drives aren't enclosures they are regular desktop USB external drives, work on 3.0.or 2.0. Any with shows before the update can't be recognized.
Sent from my SM-G935V using Tapatalk
We shouldn't need to replace something that was working before to get it to work again. DISH needs to fix whatever they changed that screwed thing up!!!!!Enclosure or not, they will all go through a small circuit board that interfaces the USB with the SATA. If you can find one that works, you can swap the bare drive with the same connection and it should work.
True, but in the meantime, if you want to try to access your content while waiting for a fix, if it works as others have reported, it may be worth the effort.We shouldn't need to replace something that was working before to get it to work again. DISH needs to fix whatever they changed that screwed thing up!!!!!
Limited time offer
