Hoppet timers: No info Available? | SatelliteGuys.US
Zaytron
44
Tucson, AZ
Today (at noon) I disable the PT to make one turner available and record 3 shows. When I check in the afternoon to make sure all 3 show were scheduled to record (on the Daily Schedule menu) all the existing timers were marked as No Info Available. I check on the guide and no icon on the shows.
Anybody having similar issues? I disconnected the Hopper and reboot but the same. Delete the timers and recreated them a fix one but other still says No Info Available.
Bobby said:
It will take several hours to repopulate the guide....
So this is normal every time I enable/disable PT?
Hopper had been working excellent since installation a month ago.
Model 5000 Help
Install happening right now
