Hotdish 95 &/or DD 90 Dishes | SatelliteGuys.US
rckowal
17
I would very much appreciate any information on these satellite dishes. Such as what material are they made from? Which is the strongest/most rigid? Performance comparisons? Personal experiences with them - good or bad? Which would you buy?
Best regards, Dick
The Hot dish is made from mild steel, its white and very cheap for what it does, you can also get the bracket that attaches to it to add a second LNB (thats what I do) What is the other brand? DD 90 ? I would say bigger IS better, its only a few millimeters bigger but its all about rain fade, I would suspect the DD 90 would be a grey dish?
The specs for the Hotdish can be found on my web site at the DMSI link!
