How about DVBU-321 LNBF? | SatelliteGuys.US
Conjuror said:
Does it work well? Should I consider another one and why? Any bad/good experiences with it?
http://www.galaxy-marketing.com/dvbu-321.htm
This is a Universal Linear LNBF. It might be a problem with a 22khz switch but that's about it. Should work fine with a Diseqc if you have additional orbital positions or a motor. The Noise Figure is a wee bit high but if you're in North America with a 30"~33" dish or larger you should be OK.. Invacom makes some good stuff.
Qbob
A question about LNB's
Slave my cband receiver with loop out?
