How are these readings? | SatelliteGuys.US
n0qcu
5,147
1,988
Earth
Finally got my Voom Installed yesterday. Bad day with the poor signal problems Voom had yesterday.
Today I checked and my readings are:
Satellite quality 28
OTA quality 80
satellite power 44
OTA power 42
Should I try to repeak my dish. I used existing dish and installer would have tried to repeak but I didn't have him since there was to much snow on roof yesterday.
OTA quality 80
satellite power 44
OTA power 42
These numbers are about the same as mine and I'm in Tampa Bay. If the quality gets down near 20, the channels start dropping out. So, we don't have much margin for rain fade. Other VOOMers claim numbers near 40 but I'm not sure if they're quoting quality or signal power.
Dana
Dana
My SAT power is 56 and my SAT quality is 54 so those number are a little low.
But yesterday my SAT power was 56 put my SAT quality fluctuated between 18-30
Bill
Please note, that signal readings are channel-specific!
It is espetially important for OTA. If you are tuned to a sat. channel, I think the OTA readings correspond to the most recent OTA channel, you tuned to...
The installer told me that the sat signal needs to be at least 30 for a successful install which seems true since yesterday I was getting dropouts when it started dropping in the 20's. Seems to be fixed this morning as I'm back above 50.
Same here I have been checking signal strength in the mornings and it used to be 30s and 40s, this morning it was 56 and 60 so I guess they must have done something to fix the probem
mine are better today, but still in the low 40's! :confused: They should be all above 50!
Picture Wont stretch
ESPN deal signed?
