How big is the OTA antenna from D* | SatelliteGuys.US
GuitarJ
2
I just called and got my HD Tivo upgrade from D*. I purchased their OTA antenna because the one on my roof is poorly installed and it's HUGE! Does anyone know what the antenna looks like (and the size) of the one I am going to be getting from D*? I won't get it till late October because of all these hurricanes comming through (they are backed up). I live in South Florida (in case that matters what they send).
If the antenna is as big as what I have, I might save the $50 and use the one I have for now....
Thanks for the info...
-GuitarJ
There is no 1 antenna that works in every situation, so I can't tell you what Directv will provide. I can tell you that if you already have an antenna mounted and it has survived the huricanes I would try and use it first then replace it if it dosen't work.
HDTV & Standard TV
connecting dishdvr522 to my home network
