My situation is that I have a modulator that sends a mirror image of my SD Tivo to all channels in the house via a Mediacom cable (using channel 69). I just had an HR10-250 installed and there is no "cable" input like there was with my old sony HD receiver. So I thought I would route the mirror thru the antenna instead, but the HR10-250 only lists HD antenna channels.
Is there any way to add non-digital channels to the HR10-250's lineup? I know it sounds silly to want SD Tivo programming routed to a HD DVR, but I have shows I want to watch still on the SD Tivo and I may use it to record programming that doesn't show up in HD to make more room on the HD DVR for the high quality stuff.
This set up works fine with the Sony, relocated to another room. There's got to be some way to access other non-digital channels coming thru the antenna; which would also be useful if the dish fails from snow or stormy weather, right? Or what if I were to split the antenna signal and route the 2nd cable directly to the TV?
Any instructions or suggestions would be greatly appreciated.
Thanks,
Sbergstc
Thanks,
Sbergstc
