How difficult to install Winegard Batwing? | SatelliteGuys.US
dschribs
20
I want to get CT local HD stations. How tough of a job is it to install a Winegard Batwing antenna? I have two dishes and three TV's. Only one TV is high def. I don't want to run another wire from the antenna so I want to wire them in "conjuntion" with the dish. Where do I actually split the antenna into the dish and on which one??
If it turns out to be too big of a job, how can I find someone around my area that will do it? Dish won't do it and they only could reccommend one installer who said he would charge "at least $400". Yeah, right.....
Great fourm!!!
The antenna you are asking about is the Sensar GS1100 is non amplified and GS2200 is amplified they need to be installed slightly differently. The GS2200 needs DC power supplied for the amplifier and is best done with a separate line to the antenna. Look on www.antennaweb.org for the correct antenna for your area. Look for an independent satellite installer in your area who has experience with TV antennas.
Dish CSR playing dumb or not knowing about free 622
Long time Sub with dumb questions.
