How do I change my time\time zone | SatelliteGuys.US
brianfont
2
The time on my guide is an hour behind. The minutes are correct so it might be the time zone. How do I change either of these settings?
You probably got installed recently. There is no way to do this manually. Turn off the receiver before going to bed tonight. You are currently running the old software. The new software is downloaded automatically every night starting at 2am. Once that's done it will fix the time. Remember to turn off the receiver. If you see two amber lights in front of the receiver, don't interrupt until it is done.
Soft Again
it's actually harder...
