How do i check signal strength? | SatelliteGuys.US
sanhin2
36
i am newbie 2 dish network and i have super dish 121, so therefore its reciving singals from difrent satellites. how do i chek the signal strngth from the 3 diffrent satellites? plzzz help thnx
Go to menu and press #6 and #1 twice , after this you will be able to se signal strengh tp (transpoder) and sat feed.Use you remote control cursors(around the OK button) and you'll be able to see your strengh on every sat pointed at(likely 119,110 121,or 105)hope this help :)
Superdish 121 and channels on wrong transponders
Question about HD OTA antenna's
