How do I connect the Video on the PVR 942 | SatelliteGuys.US
outaspace
23
I need some advice please.
I just got a Dish PVR 942 satellite reciever and want to connect it to a conventional TV.
For now, I just want to setup one TV to the Reciever and it will be my main TV.
I see that there is no RCA video cable connector under TV 1 only Tv 2.
Can I use TV 2 RCA plug to connect to my TV 1 ?
Do I have to set that TV to if I remember correctly, channels 21 to 64 ?
Thanks.
Others on this forum may have more expertise here, but yes, you can connect the 942 output TV2 to your only Television. You will need to set it to channel 69 for example, both on the receiver, and on your television. You might want to set the mode to "single" and to "shared".
Dish 1000 problems
What do you think of the Programmers at DISH?
