How do i get into Aux menu? (dishnetwork) | SatelliteGuys.US
There is no AUX menu.
AUX is use to flip your TV from TV Tuner Mode to Auxilary Mode (Video mode) not all TV's support this function though, so on some TV's pressing AUX does stange things such as turns off the TV.
If you program a DISH remote to work your TV before setting it up for another component (i.e., DVD, stereo receiver, etc.) the AUX button will do just what you say - it becomes a TV "Power" button.
If you want the AUX function to operate anything else see the list of codes in the manual.
