How do I manually add a new satellite? | SatelliteGuys.US
Alan Rovner
201
115
Vancouver, WA
Hi all I saw references to 65W Ku band in another post and discovered it's not listed in my existing list. I've never added a completely new satellite before. I think there is an XML file but don't know the location or format of the values. I'm running a VU+ Zero 4K with OpenPLi software. Appreciate any suggestions. I may not be able to see that far east but will try.
Thanks, regards,
Al, K7AR
Sent from my Lenovo TB-8504F using the SatelliteGuys app!
Thanks, regards,
Al, K7AR
Well, that's not quite as easy to do as with an appliance receiver, but here's how. I made a post some time ago on exactly how to do it. This was done on an Edision Mio OS, but it should be the same for yours:
How to add or edit a satellite in E2 based receivers
Reactions: norman881
