How do I perform a blind scan? Thanks for help!!!! | SatelliteGuys.US
comingme
4
I had the dish, lnb, twinhan_starbox.
But I can't receive any signal. Problem could be: the cable used is rg59 but not rg6. Problem could also be: dish is not aiming the satellite.
I am going to purchase cable and compass tomorrow.
But
There are several questions:
1, If I have a external reciever box, do I need to aim the dish before I do a blind scan? I mean if I just put the dish there, the lnb still might pick up some signal. If the receiver could do a blind scan, I have no need to aim the dish to the sat.
2, Is there any blind scan software for the twinhan starbox?
3, Is the must be rg6 type?
4, if I need to purchase a receiver box, what's recommended? Viewsat 2000 extreme has the blind scan feature?
Thanks very much.
But
*****Sat has to be aimed correctly , ALWAYS !**********
******Not that I know of .**************************
******Maybe not , IF the distance is SHORT .*************
Thanks very much.
*******My Fortec Ultra blind scan very well , although maybe somewhat slower .**********
Wyr
Thanks very much for clearifying ....
I had rg6 cable, compass and satellite finder now.
Working on it.
But
Thanks very much.
Wyr
Newbie Help: Installing a Winegard 76cm
Help me on satellite finder :(
